Is there anything I need to be aware of/ let the installer know when I get the kit done on Monday?
Is there a prefered allignment setup for the 02 C2 Cabs? Sorry if this has been covered before.
Regards
Arthur
no, but don't go for the wheels alignment before driving some miles with the car... You'll need first to adjust the height, because after several miles (I suggest 100...) the car will be lower on suspensions. Then you can adjust de height, run for again several miles, and if it's ok, go for the alignement.
NTTY
NTTY,
I would have thought that the car would not drive too good after the installation? If I dont do an alignment will the steering not be a bit harsh/shaky?
I can see how the car will settle beyond the initial setup height and how adjusting the height later would be the best option. A wheel alignment would not cost all that much in the grand scheme of things to do again. Thanks for the advice.
Regards
Arthur
Don't worry Australia is not that far behind in charging! I must admit though, the installation of the PSS9 is costing me AUD$650. The shop doing it, runs a racing team so I have a bit of faith in their abilities. Also they are probably the 2nd largest Porsche shop in Melbourne. The largest would be the Porsche Centre itself.
Regards
Arthur
