I had a PPI on a car done today (996TT), and one thing that was noted was a stiff clutch pedal that I was told was the result of the clutch pressure accumulator needing work. I did a search on RL and found this: PorschePhD on the subject
I just want to confirm - this should *not* be an engine out job, correct? That said, does anyone know what fixing it will run if it really is the clutch pressure accumulator (or an associated part like PorschePhD mentioned)? I'm still negotiating with the seller and want to make sure I don't agree to split a $3000 problem thinking it's a $300 problem.
Thanks!!
Justin
