I have a '02 S and want to move the AC controls to where the cup holders are. I think they are useless for most sized cups and it would be much easier to see the controls up top. Anyone done this? What would be involved and want do I need to get?
Can't seem to find it now, but I did it last fall and posted part numbers. There are several other posts that address one part of the process or another. Search cupholderectomy
It is a pretty straight forward process; and not too expensive, either.
I'd like to accomplish the same thing... but there must be a bracket or at least a bezel for it. The climate control way down on the bottom in front of the shifter is just a stupid place for it. Maybe up one slot where that stupid CD storage bin is.
I did this; it's pretty straight forward. I even moved my stereo down to the bottom position (it's rarely used anyway). I also felt the cupholders were a waste of space. Here's a pic of my interior. I'll look up the part numbers when I get a chance. You need a couple of brackets and a new face plate for the climate control. I replaced my CD holder with another storage bin, as well. Handy for phones, etc. I think this cost me all of $10...(plus the cost of the storage bins).
Edited by jmatta
Here is the write-up from PCA Tech...
Question:
I would like to move the a/c unit to the top and place it where the cup holders are.
Is this a problem and where could I find instructions?
Steve
Answer:
Yes, you can move the AC unit back up to the top, where it is normally
located on a vehicle without cupholders. First remove the side cover on
the lower console by pulling the rear of the covers towards the outside of
the car. Pull off the cover of the AC control unit and put to the side.
Unscrew the 4 screws holding the AC unit in and pull towards you. Unplug
the connectors on the rear, they only go into one of the spaces so you
don't have to memorize the locations. Next pull off the switch covers on
either side of the cupholder by using a screwdriver on the bottom of the
holder and pulling to the rear. They should pop off. Now remove the
cupholder cover by popping off the cover from the side and remove the
cupholder assembly by removing the screws holding it in. Now you will
have to fish down to get the harness for the AC head up to the top
location. To install the AC head you will have to buy 2 brackets and a
face plate. The frame is 9965576770001c and the 2 brackets to line up the
AC head are 99657350100. Just install those parts and the AC head should
just slide in the slot, install the screws and the face plate and now have
your AC up top.
Peter Smith - PCA WebSite - 6/3/2002
Edited by jmatta
jmatta, thanks for the write aup and part number info. I had not thought of doing it like you did. Yours might look better I think than the two empty slots at the bottom. Decisions.
Question:
Steve
Answer:
your AC up top.
THANKS Jmatta!! I emailed that to myself.... now to find the parts, then get them ordered... and get the cubby things for the lower positions.
SC986 - I moved the radio down because I didn't like the look of the two storage bins together.
FrayAdjacent986 - The storage bins are parts number 996.552.253.01 Upper 996.552.243.01 Lower. All parts can be ordered through "Pelican Parts" as a special order. Mine only took about 10 days to receive.
Thanks Jmatta... I think I found the bins at Suncoast Porsche Parts... something like $29 for either the pair or each... can't remember. I'll probably do the climate control release sometime in the next couple months, so I jotted down the part numbers. I kinda want to find a somewhat decent cup holder, as I occasionally go pick up lunch when I'm at work. I think ultimatecupholders.com has a decent one that should work well. Thanks again! I cross posted part of the information over on the 986forum, since someone recently asked about doing the same thing.
I have an 04 S in which the AC controls are up top, and I would prefer them to be down below in front of the shifter where I have two cubbies. The PO installed a DVD nav system with a screen that pops out and blocks all the climate controls. Is it possible to do this, and if so what parts do I need? Thanks.
If you want, when I move my AC unit, I'll give you the brackets and bezel for it for the very bottom position, if you'd like 'em.
Or another thing you might could do is switch positions of the climate control unit and the stereo/nav unit... but then that might block your AC vents!
Edited by FrayAdjacent986
BTW, all of the buttons on my climate control unit are pretty sticky. I think the PO trusted the cup holders a little too much and spilled something like coke. I can't recall, but isn't there some sort of liquid pressurized electronic switch cleaner stuff that might could be sprayed in there to clean it up, but that will evaporate and not cause a problem?
I figure when I move the unit, I might as well see if I can get the buttons working better. TIA!
That would be great! I'll PM you my details.
The bottom position only requires four mounting screws and a new face plate. You need to fish the harness down from above, but that's about it. I also have the bottom face plate, in perfect condition, if anybody wants it.
FrayAdjacent986: Get yourself some contact cleaner from Home Depot or Radio Shack; that should clean up the sticky mess. Somebody spill that in my car and I would knock them over the head!
