Hello, I have a US 2002 C4 Cab with Tiptronic and noticed the passenger headlight fogged slightly when it is on and remained fogged until it is off. I swapped the whole assembly with my friends Porsche for troubleshooting and it was not the problem with the headlight because mine is working fine on his Porsche. So far I am unable to find any relevant information about this on this site. Has anyone encounter this problem? If so what was the fix? Thank you in advance for the information.
There is a TSB on this.
You need to make sure the bumper and headlight vents are not blocked with debris. I have also seen a poorly aligned bumper cover that made this problem worse.
BTW... Porsche says a small amount of "fogging" is normal and the ventilation system should clear it in normal driving.
