A while back my brake-light indicator came on. I checked the pads, and the rear ones are a bit thin, but not too bad. However, since the rear disks need to be replaced, I was thinking to do the entire disk & pads later on. But last night, the light is suddenly no longer on. So I wonder why the light would come on and then later go off again?
-- peer
The brake indicator is just a wire that can wear through or have a bad connection. You should likely have a look at them and replace them when you replace the pads.
