Has anyone replaced them before?
DIY maybe?
Do I have to replace them or can I lube
Any part numbers?
I need to replace them. When car is cold I get a noise from engine area and goes away after warm. (Sounds like rollers on bad bearings or unlubed bearings) Squeeky
Edited by evansaero
DIY maybe?
Any part numbers?
I suggest you replace the bad ones before they break - if they break they can take the alternator and do other damage.
DIY maybe?
Any part numbers?
Would you happen to know the parts number or what they call them so I can order them.
I guess it's not that hard to replace
Found the part numbers
99610211756 TENSION ROLLER $51.30
99610211955 TENSION ROLLER $52.65
99611591370 TENSION ROLLER LEVER
Whats the difference?
Anyone know how to remove the Tension Pulley (99710211700). I can't seen to brake the nut loose and I don't want to brake the tensioner
Also for those that need to replace the deflection pulley here are the PRT#
#99710211700 Which I'm having trouble with
#99710211800
#99710211900
