I am switching from the factory rubber to the Aluminum foot rest and can't quite figure out how to remove the stcok rest. I saw a picture in a previous post about plastic nuts behind the rest, but cannot find a way to ge to them. Any help
thanks in advance
David
Here is a picture of the step. I can not
find the size of screw 6 or 9.
step.doc
Hope this works for you.
Paul
Thanks Paul, I can't see a way to get to the nut behind the pedal, maybe pull away the carpet from the top??
David
George gave me the info on removal if anyone is interested.
Pry from below with a screwdriver, and it will slide off of its tabs to the top.
FWIW, I replaced my plastic rest with the Porsche matching aluminum rest. Looks better, but for $160.00 I was disappointed at the quality, still mostly plastic with a little aluminum showing through.
Do you mean to pry the pedal straight up or outward. Still nervous I'm going to bust it. I want to do the same replacement, it bugs me that the dead pedal does not match the others. It must now look better even though it's mostly plastic.
