I retrofitted the OEM HID lights using the DIY instruction to my non HID equipped 996 a while ago and it worked perfectly for a while, but now i 've a problem. I cannot turn on the head light normally anymore. the only way i could turn on the headlight is I ve to turn on the fog light, shut off the fog light, then the head light will come on. if i just turn the dial to the right, only the parking light will come on. any helps????
