question: am using trickle-float charger on C2 thru the lighter socket. Will the same charger-socket setup work for other late model cars,ie:BMW,Acura? Are they set up to be charged thru the socket the same way?
Appreciate answers from Loren and all.
As an aside I use a trickle charger. They are supposed to "top off" the battery. Well, my battery was 4 1/2 yrs old and was 'low' The trickle charger stayed on all winter, but could not provide enuf of a charge and the car was stone cold dead when I returned. Had to buy a new battery of course. So make sure you've got a good charged battery to begin with :)
I don't see any reason why it would not work as long as the lighter is not switched (always on).
All of what Loren said, plus I use my BMW Trickle charger through the lighter socket on my 911 as well. Always works great.
