I guess that would be PCM 2.0 to PCM 2.1 would this be a plug and play upgrade?
First, PCM2.1 Retrofit kit includes head unit, navi, copper wires with some connectors. no manuals, no optic cables, no dvd cover.
No, you should connect system tester to make codings in pcm modules and gateway units, all depend from year of the car.
But in common case system should work, with errors and not all devices, C-F, km-Mls, FM/AM step
In some cases you should connect tester to switch unit on first time, or wake unit up.
You need slightly modify wiring for head unit if where no tel unit installed/ sos button in roof console.
A lot of variants, suggest to do it in workshop, it should be about 7.5 hours to pay, including all - removing/installing all trims, and roof lining, seat, gps antenna and routing all cables. In fact, it take up to two days.
Alex
