My fan does not seem to be activating even after a spirited drive. It used to always cycle on after turning the engine off. It has been cooler (30-50 degrees F), but I am still surprised it doesn't come on. Is this normal in cool weather?
Yes.
The engine compartment fan is a purge fan - it will only come on when the engine compartment temperature exceeds a set value.
Then it will turn on and pull cool air into the engine compartment.
