I just took delivery of a 2006 Cayenne Turbo. I was under the impression that the Turbo and Turbo S had the heated Steering Wheeel as standard. The vehicle is pre-owned and came from South Florida. I am in Ohio and the weather is certainly cold enough that the wheel should heat. I assumed it to be in-op. When I went back to the selling dealer he indicated that it is an option and this vehicle does not have it. Is there anyway to confirm that this vehicle has the feaure or not? Thanks
Thanks Loren - It appears there are two downloadable copies of the Turbo S Order Guide. Am I missing the location of Turbo (non S) version?
You are correct - I removed the duplicate.
What you see is what Porsche delivered for order guides for MY06.
Because of the face-lift versions there were almost no changes for MY06 Cayenne's.
