I have a broken hinge on the oddments tray and have found the following link which talks about a retrofit kit so that the complete lid doesn't have to be replaced.
http://www.renntech.org/forums/index.php?s...ents+tray+hinge
However, I note that TSB 6848 refers to the 996 only. I am aware that there is many common parts between the 996 and the 986 but can anyone please confirm that the instructions and the kit (Part No. 996 552 960 01) are also applicable to the Boxster S (986 MY 2000) ?
Thanks in advance for any assistance
A bulletin was also issued for the Boxster. The only difference is that the 996 has a strap and spring that the 986 does not have. The repair kit is the same.
