My 2000 996 has 26000 miles on the clock, but the last year has developed a strange problem. I have a problem starting the car only after refueling at the gas station, other wise it starts and runs great. After fueling I have to pump the gas pedal several times while cranking the engine before she fires up. I recently purchased durametric software to chase down the CEL that intermittently comes on. The CEL code is a P0440 "Fuel Tank Ventilation System" fault code 93. Has any one else experienced this problem and if so, how did you correct it. Thanks for any and all assistance.
Joe C.
Joe,
do a search by "P0440" or "Tank ventilation" and you will find a good bit of information. Could be as simple as a gas tank cap replacement or you may need to get to the Evap canister or filter. All in there when you do the search.
Izzy
