ok, took me approx 2 hours, the most trouble i had was with the dreaded plastic bushings on the orig shifter (they were a b.i.t.c.h.). i worked with a small jewelers flat-screwdriver and soft hammer and basically wedged/broke off the bushing clips/tabs. they seriously took most of my time, almost 20 min. the re-assembly is a breeze, i can see how people could do it under 1hr the second go-around (i was overly anal about the project). anyhow, the tape on the cables and also counting the threads made all the difference in the world. the throws are unbelievably short as compared to the original, and i have no problem moving in and out of the gears, including reverse.
THANK YOU ALL FOR YOUR HELP AND ADVICE!!!
GHL on Tues/Wed
oalvarez
cc: 6speed and rennlist
Several years ago I started to use a wood chisel and a hammer, and the plastic tabs just pop out in about a minute for both sides. The Porsche instructions that came out a few months ago say to use a chisel.
hey Tool Pants,
nice Rolex  :thumbup:
I have a $20 Casio which I take off when we work on cars to protect the plastic. I will tell Santiago in the picture you like his watch.
