Hi everyone,
I've had kinda a funky problem surface with my '99 C2. My dealer performed an early 60k service on my car a few thousand miles ago, which corrected a slight hesitation that occured at approx. 6k on full throttle run ups. However, since that time, my car began idling horribly, or better, not at all. I had been ignoring this for lack of time, and finally decided to check into it. After I changing the oil recently (I've done many full engine overhauls myself, so yes, I'm perfectly capable of changing my own oil :) ), I noticed a connector that was loose. Oddly enough, it was the mass airflow sensor that had been disconnected for a good 6-7 thousand miles. Puzzled, I reconnected it, and immediately the idling problem was gone. However, now on full throttle (and only on full throttle) I get significant hesitation from 5.5-6.5k, and I'm definately not getting full power. I discovered the check engine light had burned out, explaining why I wasn't getting a light, and I had 1123, 1125, 1128 and 1130 codes (lean and rich for each bank). I've cleaned my sensor as outlined elsewhere, but my problem remains. I'm wondering if this is definately my mass airflow sensor, or possibly something else. Before reconnecting the sensor, the ONLY problem was the jacked-up idle, other than that I had no issues with power or hesitation. Any ideas?
Edited by way2fast
Based on the mileage and the codes it could be the MAF but also the Oxygen sensors. Mine had lasted 62K miles, and from other readings in the forum seems to be about the life.
I threw some O2 codes last week. One was an O2 adaptation. I reset but it came back (solid check engine) the next day so I took it to the dealer. Turns out it was a vacume leak and the only way to get the line replaced was to drop the engine. :rolleyes:
I should get it back tomorrow... $1K rubber hose.
Just over 75K miles btw.
I already cleared the codes once, and have the sensor reconnected now. After a bit of driving, the codes come back, the same 4 as before. I have to say, the hesitation seemed to actually get better after I cleaned the sensor, but I'm still definately getting a loss of power.
My '99 Boxster experienced the exact same conditions, hesitation at ~5500 rpm and same CEL codes. I cleaned the MAF and it got better, but codes returned. I eventually replaced the MAF and all is well, no more hesitation, no more codes. Good luck!
Thanks for the info!
Looks like I'm buying a MAF sensor. Being new to the 911 community, I don't know the best online sources for parts and equipment. Who's the best?
Sunset Porsche (on the links above) is a good bet, they run specials on MAF and O2 sensors regularly.
