What is the voltage to the PSE solenoid to activate it.. Since it comes from the DME I wonder if it's still 12 Volts. It seems to work very easily with a 9volt battery. I intend to direct wire a switch from an ignition fused source to the solenoid for direct Off/On without the DME interruption and I don't want to burn it out.
If I get the info and it works I will post!!
