  • 3 months later...
I think you may also need the PIWS tester to set the beam angle since the lights are controlled by servo motors internally. OEM fittment includes a controller for the lights and sensors on the front and rear of the car to determine the ride angle.
Thanks, after careful deliberation I have decided to forgo the factory system, I bought a aftermarket kit and I am fighting the install now! :cursing:
The Canadian spec cars all have daytime running lights activated, the headlights are on all of the time, which isn't the biggest problem....
They (Porsche) use a modified voltage signal to drive the headlights, sort of a 'pulsed DC voltage' that drives the ballast crazy. I can run the lights off the battery, the problem is finding a switched source so I can trigger the relay to drive the lights.
So far everything that I have tested has this modified voltage. Bummer!
