Annoying rattles in my cab on small pavement irregularities. mechanic thought it to be the side vents. A little searching & I found the rattles in the sunshade mounts. Each one has two screws. Two of the threaded pieces these screws go into had cracked (one on each side) and the screws sitting rattling around in there. (Perhaps over-torqued at some point?) The threaded pieces do not appear easy to replace, but as my extended warranty should cover them I guess I'm ok. It's much quieter with the loose ones out and the other two mildly snugged down. Now it seems there's a slight rattle in the cover for the top's locking mechanism ...
