Good day everyone. Finally found sometime to replace both CV boot on my 2000 S. During the removal of the drive shaft the brake had to be remove among other key parts in order to extract the shaft. After re-installing everything, the "brake ware light" came on and stayed on during my test drive. How did I activate the light from removing and re-installing the brakes? Or is it just momentary and just need to re-set it. If so. How do I re-set it?
Ben
Most likely your brake sensor wire is broke. It's very easy to get brake, and I usually order pair of sensor wire with brake pad.
Take your wheels out and inspect your wires.
Ben
Hit the nail on the head. I removed the brake the following day, good enough one of the two wires was broken looks like a clean I don't how I could have dut it during the removal or re-installation. Thank for the heads up. Everything is workind as they should.
Ben
