mechanical lsd limited slip differential
Does any one know which of the 996 models have a mechanical slip differential?
Is it the pre 2001 models or is it just the pre 2001 carrera 2 only?
Many thanks!
It was an optional extra on the 3.6 996 C2 (option code M220, I think). It was standard only on the "40 years anniversary" model.
Thanks for the info, had a 1998 options list lying around have figured it out:
1. Mechanical Differential lock and traction control cost £985 UK back then
2. Traction Control (with Tiptronic S) £850
Looks like the options for that ran only in the 1998/1999 cars before PSM came in 2000 with the carrera 4.
So has anyone tried the difference between one with the mech diff and one without or with the computer diff instead. Would be interesting to see if any difference?
  • 5 months later...
Really? So none of the "regular" 996s had a LSD unless optioned that way. I have a 2002 C2 with no indication of the LSD option, but it sure drives like a car with a LSD. Does Porsche use some other technology to simulate that sensation. I do not have any form of electronic traction control that I am aware of either.
I find this amazing and just wanted to confrim that I am reading this right.
Thanks.
Many thanks!
How can you tell if you have it. I have a 99 c2 but my option sticker is gone. last month i was changing my triptonic atf and the mechanic told me i have a lsd . Can any one tell me how to check to make sure. I do not have TC.
Many thanks!
Many thanks!
Does any of your paperwork have the transmission model number? Should start with G96...
Many thanks!
No documents to check I check the tranny model number to see
I'm not sure about other models...but I have the toggle switch on the dash that turns the PSM on and off. It alsways defaults to on. Since the options for the 99 always included both the codes of 220 and 222...wouldn't they have to have the toggle switch to turn the feature on/off? Maybe my approach to this is too simplistic??
