while replacing the driverside window after it smashed i diconnected the side airbag now the airbag light is on the cluster and won't go off i have disconnected the battery for a sizable time but it won't go off has anyone got any ideas
it's 98 boxster 2.5
For safety (legal) reasons you can not turn off an airbag light by disconnecting the battery.
You will need the Durametric Software, or a PST2 or a PIWIS tester to turn off the airbag light.
Where are you located? Perhaps there is a member close to your location that can do this for you.
in the uk essex i have considered investing in the diagnosis software though how much is it and where can you get it
http://www.durametric.com
Price will depend on which package you order. Anywhere from $247 to $597 as I recall.
Still, much better than a used PST2 for $3300 - $4000 on eBay... :rolleyes:
I am in the UK (East Sussex) and I had the same problem when I did a 3 spoke steering wheel swap. I contacetd my OPC about it and they told me to bring the car in. They re-set it and charged me zilch. (oh and even found the PCM codes for me at the same time, again gratis)
Give em a bell - might only cost you the price of the call.
