I have a 2004 S (550 Anniversity Edition) and would like to replace my factory pedals. I am looking at Rennline and Ultimate Pedals. Does anyone have any comments, recommendations, experience with either of these products, installation problems, etc.? Thanks!
i also have a 550 SE :)
you can search the archives here, at babblers.org, orppbb.com for many reviews of aftermarket pedals
my main installation tip is that the brake pedal is very hard
get a new drill bit from home dept, and place tape on the brake area so you can mark where to drill
make sure the area on the underside of the pedal is clear so you can place the nut there (there are fins on the underside of the pedal)
use needlenose pliers to hold the nut while you are screwing from the top
aloha
steve
you may also want to put some loc-tite on the screws so they don't come loose
i second the loctite recommendation. it is essential.
you can buy it at AutoZone or another auto parts store.
aloha
steve
