I did a search and saw other folks mentioning that their speedo shows roughly 10% more than actual.
Mine is approx. 4mph higher at a wide range of speed compared to the GPS.
Do you know how can it get corrected / calibrated?
Is there an OBD type tool at dealers to go in and change a variable / modify a correction factor to fix it?
TIA
