Hi:
How can I tell if my MY99 Carrera C2 has an on board computer even if it does not have the controlls or does it has a computer and all I need is to activate it and install the controlls?
Also what is "16 mm triple square with a hole in the middle" for transmisson oil drain plug removal?
Edited by hi8ha
Yes, a MY99 has the OBC as standard.
It needs to be turned on using a PST2 or PIWIS tester.
From default you will get outside temperature - if you want the rest of the OBC functions you will need to install the OBC stalk or do the OBC hack described elsewhere on this site.
Thnaks Loren.
Could you expain me this: Also what is "16 mm triple square with a hole in the middle" for transmisson oil drain plug removal?
