Doing an upgrade on my S to fit the Nav TV Ipod interface... all going well till I nicked the fibre cable with a knife! I now have a dodgy connection at the rear of my PCM module. Any ideas on where I can get a termination tool for the fibre optic... please....
Many thanks.
Mal
Many thanks.
Mal
Replace the cable, fiber is difficult to terminate
Yes I thought about that but the fibre goes into the loom & then off into the distance.
Not really an option unless I can find where it runs.
Mal
is it one strand? if so just connect the ends and put some tape around. it is optics so who cares how dodgy the connection as long as light goes through. you can try this at home - pull your optical cable out of DVD player or home cinema amplifier and as long as you can shine the light from cable into the hole it will play.
P.s. i realy like HiFi shops selling "Best" optical cables with gold plated connectors - ultimate test of human stupidity
Depending on the fiber optic emitter, the cable quality *IS* important, running a loosely repaired cable will force the emitter to retransmit the signal at an abnormaly high rate...
Maybe you can try shops like blacbox which carry IT fiber optics tools & cables for reasonable prices
or from an electrician doing IT cabling, as fiber optic is widely used in modern buildings
probably cheapest than paying a Porsche Dealer to fix it !
just my 2c
Thanks for the info guys... it is now sorted.
Take 1 x lollipop stick, remove lolly, cut back broken fibre on both ends, insert each end into hollow lolly stick until they touch, tape up, test & thank your lucky stars that the car isn't in to Porsche for a VERY expensive repair. I would like to take credit for this but it was the guys at Nav TV Uk who advised the fix.... it's been done before!
The Ipod interface works really well & the sound quality is fantastic with full control over the Ipod. Highly recomended.
Thanks again.
Mal
£350 UK pounds is the UK list price, they gave me some discount as I am a TV / Audio dealer. Got it direct from NAV TV UK. Works very very well... a few software bugs but nothing you can't live with. I am that impressed that I want to get one for our Touran but they don't make a VW interface. Looked at the Dension gatewaty & that is limited to five playlists... no good.... I have 3000 + tunes on my Ipod..
Mal
