Does anyone have a typical damping setting on a PSS9 for 996TT? I've changed it and now I'm lost. Car handles like SH**T now. The more I play the wost it gets. All info ould help.
Start back at zero for all. Then listen to the clicks (or feel them). I have mine set 3 in the front and 2 in the rear (I have the FVD, Euro, Version). I am running 18" 235/40 and 315/30 MPSC...this will matter. If you are running 225 & 295, 4/3 will be fine.
Edited by wross996TT
If you have lowered the car lately this can also reduce the handling, if you set the PSS9 towards gt2 height the pss9 will bottom out to early which give lousy handling.
Ive heard 4 front and 3 rear as good setup.
