faceplate part #
If you mean the rectangular frame that goes around the climate control then it is 996.552.677.00.01C.
If you mean what is inside of that frame - then that is the control unit itself - and that will be expensive.
Or part number 996 552 339 00 01c if you have moved the control unit to the lower console; Normally if you had PCM.
i want paint the whole climate controll
