If I disconnect the negative terminal to my battery that will 'disconnect' power to the car. When I start it again, what happens? Does dealer have to reset anything or is car (electrical systems) back to normal?
I assume you have to leave the ignition in position 1 to prevent the secondary siren on the alarm sounding when you disconnect the battery, as you did on the 986/996 models.
