I'm so dumb. I'm taking my 99 Boxster into the shop Wed. at 7am to have them check it out because I just got it and at 60,000 miles I wanted them to look at it. They are going to change the oil and do a 60,000 mile maint. At $600 est. I just realized I should have been asking you guys what really needs to be checked. IS ANYBODY OUT THERE, OUT THERE.....out there ? Thanks a lot... Brad
600$ for the 60K maintenance sounds cheap if this is done by the dealer.
I called 3 of them (Claridge, Carlson and Steven's Creek) and they run between 1000 -1200$ ( depending if they replace the polyrib belt or not).
600$ might only be the "services" charge, oil, brake fluid, filters might be extra.
The more usual problem on Boxster are:
Rear Main Seal (aka RMS leak)
Valve cover leak
MAP sensor failure (it get dirty and the check engine come on)
wheels bearing failure
retractable top cable snap
Collant reservoir leak
Oil filler tube leak
Most of these problem can be observed by monitoring your garage floor.
Hopefully everything is going to be ok
Jean
OK... here's the breakdown..(No dealer here in Lexington)
Parts $640
Labor $458
oil
oil filter
brake disc 2
brake pad set
brake pad sensors (Should this be a separate thing from the pads ?)
fuel filter
spark plugs
air filter
acc cabin filter
poly rib belt
What do you think? Thanks Brad
Parts $640
Labor  $458
oil
oil filter
brake disc  2
brake pad set
fuel filter
spark plugs
air filter
acc cabin filter
poly rib belt
I did the 60k service on a friend's 1998 for about $180 in parts, no brake pad change was needed.
The sensors are a separate item from the pads. There is no reason to replace the sensors unless your warning light is on. We replace pads all the time without replacing the sensors.
You might want to add a brake fluid/Clutch flush, if they are going to repalce the brake they will have access to the bleed nipples, and flushing the clutch is prety hard when the car is not on a lift (unless you work for Cirque du Soleil).
The bake job is kind of costly on the parts (~ 200$ each brake pad/rotor set) If you have time, you might ant to "shop" on the internet for a better deal.
http://www.sunsetimports.com/porscheatcost.htm
Is a place that we use down here. They are a Porsche dealer that is willing to sell for less when you are not in their market (i.e. Oregon). They carry everithing you will need, including the polyrib belt.
You could possibly save 70$ by not buying the "charcoal" polen filter (if you change it, go for the "cheap" paper one). I alway wonder why they would fit a polen filter in a convertible...? ( I assume that it is the same ventilation system that the one used on 996, so they did not bother creating a new "SKU" without polen filter for the Boxster).
Oil, sometime Kragen or Pepboys are running promotions. Go and buy your 12 quarts of oil in advance. Mobile 1 0W40 cost a lot, so stock it when it is cheaper.
Jean
Edited by frenchy
