Could not find the pinout for the ECU of my MY06 987. It supposed to be a Motronic ME 7.8, and had to add some external electronics to take care of the Variocam Plus (valve timing + lifting).
(MY06 3.2 987 S engine has the "old" variocam, with no valve lifting adjustment. Since replaced the engine with MY06 997 3.6 I need to take care of lifting which was not possible using the original ECU alone).
Any ideas where to find this? <_<
Okay, just to be a little bit more specific: what is the A1 connector? It is called "term 15" and it connects to something named "SP044_SPKL15PAS"... :help:
Great! Thanks! You just saved my day :renntech: Could Term 38 (A2) be a 12V also?
(Ps: I need that switched 12 to operate the valve lifting electronics, but the Amp-rate maybe too low for that - so will add a relay and thread a thicker direct 12 there...)
Edited by csory
