Okay, after doing some battery disconnections (due to some work around the ECU) would like to be sure about the exact procedure:
1. Re-connect the battery terminal(s)
2. Switch ignition on, and leave it so for at least a minute - without touching pedals, controls etc
3. Switch off ignition
4. Fire up the engine and let it idle until the idle settles (5 to 10 minutes), again, not touching pedals or controls (except clutch to crank)
Am I right or missing something?
