Over 18 months of trouble free running of our '99 996 (127k on the clock), and today the car starts running like it has 2 cylinders rather than 6. Plugged in the reader and got the codes mentioned in the title. So thanks to the fault code listing on this site, I learned what I already knew . . . ie misfiring in cylinders 1, 2, 3 & 6.
I will start with the usual suspects this weekend and trouble shoot the ignition system.
I did not have the car running when I read the codes. Should I try that to see if I get a more precise indication of the problem??
Of course any and all thoughts are greatly appreciated.
TIA
Marc
Edited by marcesq
These could be damaging to the TWC if your CEL is flashing - so keep that in mind.
A car with a flashing CEL should not be run or driven.
Recent refueling? bad fuel?
Any recent work - like spark plug replacement?
If so, check for cracked coils or poorly connected cable/coils.
Any smoke from the exhaust - like oil burning?
Thankyou.
Refueled right before problem, drove about 15 miles and then problem started.
No recent work
No oil, or anything else, coming from exhaust.
I didn't have time to work on it this weekend, but will start with replacing the fuel filter, then deal with a full tank of gas.
Cheers.
  • 2 months later...
Ok, it's been a long cold winter. Changed the fuel filter and drained the tank. Added 4 gallons of fresh gas and no change.
Symptoms . . . to start car pedal needs to be depressed about 1/2 way. The car will not idle. If the pedal is release it die after hard "chugging" for about 10 seconds. After starting if I keep the car over 3000 rpms it will keep running but not smoothly.
Any thoughts?? where I should start.
Thank you.
Marc
