I installed the new becker Cascade Pro in my 2003 Carrera 4S following the instructions I found in the forum and everything seems to work well: telephone, bluetooth, GPS, Clima copressor. Except one thing: the unit turns off every hour then I have to turn it on and again it turns off after one hour !!
Anybody can help me?
Regards
Gianluca4S
Regards
Gianluca4S
Sounds to me you may have miswired the power inputs to the radio as the radio is acting like the key is out of the ignition and you have manually tured the radio on which usually allows one of playing time before shutting off to save battery. Usually the power to radio is switched from ignition switch, so look at pin outs of radio schematic and how you wired power from ignition.
My 2 cts.
'demosan
