My stereo doesn't work and the stereo shop said my amp is missing and should be on the left side of the trunk near the front(right side if facing car). I pulled the carpet myself when I got home and found what looks like an amp on the front right side of the car(left if facing car) with green connectors near the CD changer.....isn't that the amp?
ghghgh that is the AMP. It doesn't make sense that your technician told you the AMP is missing. Unless if your car was broken into and you didn't know it. If I was you I would start by checking all your fuses.
Ed C.
