I have a CF GT2 rear wing that I'd like to fit for trackdays, only problem is its missing the screw-in mounting lugs that attach it to the lifting rams in the rear wing. Where can these be ordered? My Porsche centre can only supply complete wings at $6k AUD and none of the Porsche breakers I spoke to have them.
I don't want to remove the lugs from the standard wing as I want to interchange the wings and the lugs are loctited in place. It also seems likely that either the lugs or the wing will be damaged by removing the lugs as I used enough force to sheer the head off a 8mm bolt without the lug moving.
I've also been offered a cheap GT2 exhaust system. The seller says it increased the power to 530bhp on his old 996TT when fitted with a chip, filter and mapping. Will this have any adverse side effects, eg reduced power at low revs or lumpy running?
Edited by SpawnyWhippet
