I am about to install the spoiler switch in the center dash. I have a 03 996 with the one piece surround plate. Is there a diagram showing how the plate is attached to the dash? I don’t want to break anything when removing it. :help:
Instructions have been posted several times. Just start lifting the trim from a corner and go around the piece with your fingers as you lift.
Yup, Like Jeff said, just start prying....but be careful not to scratch the rest of the Dash. I found it best to start from the bottom corners and pry.
