  • 2 months later...
Aloha All,
I've read all of the "oil filter wrench" posts, but I still have a question. I've changed the oil twice on my 03 Boxster S, using a strap wrench. Since there was no problem at all with the strap wrench, of course I had to go and buy the correct cap-type wrench, to do BETTER than "no problem" on my next oil change.
The closest I could get at the nearby NAPA store was their Evercraft End Cap Filter Wrench, 76 mm, 14-flute (775-9007). Inside the wrench it says 76-14. I thought I'd try it today to see if it fit (even though its not a 74-14). I was expecting it to be too big, but it is too SMALL, and I couldn't get it on the filter housing. From inside center of a "flute" (which is acutally almost perfectly flat) to the inside of the opposite flute measures out to 75mm.
Any ideas what's going on here? Is there something about the wrench shape that could be different from the "right" shaped ones, even though the size is larger? It looks like a regular cap wrench to me.
So as not to make a complete fool of myself, I just put the car back on the ramps and double-checked...the cap wrench is too small.
Mahalo for any assistance.
John
Aloha All,
John
I use a Harley Davidson filter wrench on my bike (FXSTB) and the 997 - it's a 76-14
