There appear to be two versions of the CDR-220, a model 4462 which was available for 99-01 MY 996 and Boxter, and a model 6625 which was for the 2002 model year. My question is whether the latter will also work on the 99-01 MYs or whether you must use the 4462.
In looking on the Becker site, you can download the manuals, but the 4462 manual is what downloads for both the 4462 and the 6625.
My 1999 came with the CR-220 (cassette only) version, which I'd like to replace with the CD version. I know that there are better head units out there, but I like the original look of the Becker systems.
Thanks in advance.
Randy
I suspect that the model change is the changeover from the standard audio wiring to the MOST fiber optic system. Loren can likely confirm that information.
