Im a bit suspicious about the mileage on a cheap 99 996C2... does anyone know if there is a way to double check before i go and ask the dealer?
thanks in advance
kelvin
thanks in advance
kelvin
I do not know how anyone could change the mileage on the odometer without getting into the computer and resetting a bit or something. I would hope the folks at Porsche are smarter than that.
How cheap is cheap? Did you do a PPI? , have any maintainence records? and for what it's worth, a carfax?
You can find out where or who the original dealer was with the VIN # and see if thay have any records. They will have the milage and services performed and the dates they were performed. If the car was serviced at at porsche dealer, with a little leg work, you can see if the service records support the milage on the odometer. What does the car have for options? and what is the milage. I looked at a 99 c2 with 105K for $23 k. Is this a private sale?
Good luck
thanks in advance
kelvin
Good luck
Have a dealer check on the number of engine hours. The mileage divided by the number of hours should be a reasonable number. Don't be affraid of the cheap price... 996 prices have fallen through the floor especially this time of year.
As stated above, the rule of thumb is the engine operating hours in the DME.
I assume you are really in Germany. There are other checks/searches that can be in the US on the internet or at a Porsche delearship, but I have no clue about German cars.
The original DME on my 1997 Boxster with 51,000 miles was replaced last year because it was defective. The defective DME had 1,622 operating hours. The new DME had zero operating hours when it was put in, so the rule of thumb does not work with my Box.
http://www.renntech.org/forums/index.php?s...4331&hl=DME
thanks guys for your answers...
toolpants:
if the car has a new engine does that mean that the "DME" gets reset? or replaced with the new engine?
btw. i am in Germany :)
cheers
kelvin
The DME is not reset to zero - the DME is not replaced - when a new engine is put in. The info in the original DME continues on with the replacement engine.
