On my 2000 Boxster S I am having trouble reinstalling the pan under the tranny. Not all the holes will line up at the same time. I noticed it was difficult to remove. It doesn't appear to be bent. Is this a common problem?
Anything to make it easier?
Yup, I just had to deal with this on my 2000 Boxster S last Friday. I had changed the transmission oil and had a heck of a time getting that pan back on underneath the transmission. It was a lot of trouble getting it off too. It seems that there's a bit of an interference fit there and/or it's just an extremely tight fit. I knew I'd run into this though from the trouble I had in taking it out, so I just drilled out the four holes (two on each side) in the pan where it attaches in above the aluminum bracing. I did not have to drill out the two rear-most holes. I drilled these holes just slightly larger and the pan slid back on with no problems - no more interference. Should be easier to take out in the future too.
