Does anyone know what are the big differences between the
Porsche battery maintainer (98061198100), which sells for about
$76 bucks, verus the Porsche Charge-o-mat which sells for
over $100 dollars.
Does it matter which one I get?
over $100 dollars.
Hi
I purchased the charge o matic because I have 2 " Garage Queens " , a 2004 BMW 5 series and a 2006 C2S. Since the systems in the BMW will go to a " default mode " and have to be reactivated, I hook up the BMW to the charge o matic and it will KEEP the battery at its best charged level,. All you do is hook it up and forget about it. If I leave for 2 weeks, the BMW is the most sensitive to not driving it. The Porsche seems to hold a charge longer... Basic I believe the " Charge o Matic " can be left connected to the battery for long term situations and will keep the battery at a constant optimum charged level so the computer systems which cause slow drain, will remain active..all this without your constant attention. This becomes important to me when I leave for 2 weeks....Anyway, I have found that the " Charge o matic " has prevented low battery levels for both cars, which will cause to battery to have a " Heathier, Longer Life". Once the charge o matic has charged the battery to full charge it will reactivate when it drops to a preset lower level. I'm Happy with it.
Larry, North County San Diego
