I usually don't drive the car in the cold., REALLY COLD FOR MOST READERS ( 28 F). There was a squeaking noise on turning the wheel and I wondered if there was something on the steering rack that could make the noise. Another time, I heard a similar noise on turning and going over a bump and wonder as well if their is something on the front strut that would do the same thing? Bit of a nuisance but probably not serious I hope. That said, depending on what it could be how do you fix it?
If you turn the wheels while parked on level ground can you reproduce the noise?
or
While the car is at rest on level ground can you reproduce the noise by (gently) pressing down and releasing the the suspension?
