Gents:
I have a 2006 997s. I changed the oil myself at 1800 miles ( 1 year ) , a very easy procedure and much less expensive than the local Porsche dealer. ( Mobil 1, 0w40 ) Before the oil change, I was getting 14.5 mpg. Afterwards, my fuel consumption dropped dramatically to 23 mpg. I am totally sure my driving habits have not changed. Has anyone experienced the same change?
Larry, North County San Diego
Gents:
Did you mean dropped or increased? Either way I changed my oil at 1900 miles and did not notice any change in mpg, I was averaging 25.5 mpg before oil change and average is now (3000 miles) 25.1 Best recorded mpg before oil change was 29 (fully loaded, mostly motorway cruising at 80mph, <4000rpm) and best since has been 27 but with a mixture of road types and now using the car's full rev range. (Note: mpg figures are based on imperial gallon for equivalent US gallon multiply by 0.833, fuel mostly Shell 99 RON)
Edited by snarf
Gents:
Sir:
My fuel consumption improved from 14.5 mpg to 23mpg. I drive city and freeway miles ( not many however ) Punch it once in a while. My point is that my mpg improved after the first oil change.
Larry
Sir:
Larry
Larry, apologies, your meaning was clear - I should take more care when reading posts.
Wow, 25 mpg!!!. Is that highway or combined City and Highway? My best is 22 mpg on highway avg 85mph. If everyday city driving, I get 19 or so. I don't think I have lead feet. I figured my mpg is the norm, Is it ? Board? I am happy w/ 22mpg. But if 25 mpg is the norm, What am I doing wrong?
My circa 25mpg is per imperial gallon this equates to around 21mpg per US gallon. Also I never start the car unless its for a minimum of a ten mile trip, I avoid rush hour and traffic hot spots wherever possible and I have only once used less than 99 RON fuel.
  • 4 weeks later...
My numbers range from 14 mpg (US) (when really playing) to a bit over 24 mpg,--when on a highway and not starting and stopping. Cruise set at 70 mph. This, with a VERY full cabrio and h/top.
Dan
19.7 mpg US. It doesn't budge. I think it's a number the factory etched in the indicator screen to make you think it changes... :jump:
Dan
