Anyone have an idea as to why the interior lights would not shut off in my 993TT? It has just the standard rocker light set ups over the doors, not the optional interior sensor system up by the cenert rear view mirror. Lights do not time out, or shut off with locking or when doors are shut...only if you manully leave the rocker light swiths to full off. Gremlin?
I would start simple. Perhaps the switch in the door jamb that activates the lights has gone bad.
  • 2 months later...
Mine had the same problemm. I took out the door switches and cleaned them Also the front trunk latch turns on the inside lights.
