99 C2 cab ... hard top squeaks from the rear over every bump in the road. Can this be lubed somehow without removing the top completely? Or do I have to enlist a neighbor for the afternoon?
Vic
99 C2 cab
There is a 14 page TSB with fixes for a number of hardtop noises. I can email you this if you want or you could make your dealer fix it. There is also a TSB about new latches - do you have those?
Thanks, Loren ... vjd3@yahoo.com
The car is a 99, so it's not under warranty, although it is a Porsche certified car, the dealer said adjustments are not covered. I doubt I have the new latches.
Vic
Edited by vjd3
You have a certified car and the dealer said that they are not covered? BS! I just took mine in and had them eliminate a number of rattles and it was all covered under the certified warranty.
Edited by DaveMo
Loren,
Could you email me those TSB about noises in the hard/soft top of 996 cabrio ?
Antonio
Antonio,
That is many TSBs! Do you want start with just the hardtop?
Can you please send me these TSB's for the hardtop and soft top. I have a 99 c2 cab. Thanks very much in advance. DJbrand1@aol.com
