So I was doing the front PSS9 install on my 2000 C4 and everything went well until I torqued the nuts on the top of the spring strut mount in the bonnet. I sheared the rear bolt right off the strut mount.
I've got some questions:
1) Does this matter
2) Should I replace with aftermarket sprint strut mount or OEM?
3) Are there aftermarket options?
4) What is the part number for the OEM mount?
-Ross
1. Yes, think if all the stress of cornering has on that mount.
2. and 3. You could use either. I think TRG has them as well as others.
4. 997.343.018.00 (yes, this is a 997 upgrade part from the 996 part).
