Hi fellows,
I did a search but couldn't find the solve, hope you can help out.
I have a 2003 996 C2. I removed the instrument cluster and the three sets (white, blue and green) of wires back of the gauge. After I am done I put them all back together and I get 5 warnings: Oil level check fail, Outside temp check fail, Oil consumption fail, etc) How should I get rid of these warnings and more importantly, is it safe to drive the car with these warning? The car starts normal, just that I can't read the oil level, outside temp, etc.
Please help.
Thanks, in advance.
Andy
All of the warnings you are listing are on the B connector (blue).
You should remove the cluster again and make sure the blue connector is properly connected and locked.
Many thanks Loren. It works properly now.
Andy
