Battery is fine and car too, but the hood just wont open, using the car keys or button in the car.
Any ideas what can be wrong?
05 Base Boxster 7,000 miles
Can you hear the actuator firing or does it not even work when either of the opening buttons are pressed?
Try pushing lightly down on the latch when opening via the buttons. There is an emergency cable but try to narrow down the issues first.
Regards
Popolou
Well i would suggest that if you don't hear anything from that end when you activate the lock actuator then you're looking at a faulty unit. Otherwise, have you checked the fuses or do you know if something has got caught (such as a fabric) within the latch and locking mechanism?
If the car has warranty, then a simple visit to the OPC should be enough to get you back up and running.
Regards
Popolou
