Got my springs and am starting to size up the job. Any one removed the Bose sub woofer that covers the access to the rear spring tops. There must be some trick to releasing it.
Ther is some article some where on removing the speaker box.
You start by pulling out the two plastic air scoops near the outside panels.
A small screwdriver will help pop them out. Then you will
use a torx wrench to remove the bolts that hold the speaker box. Remove
the box and underneath the carpet you will see the computer for the car.
Paul
1. Remove the cover trim at the left and right towards the front - by simply pulling it off.
2. Unscrew the fastening screw on each side.
3. Pull the sound package in the towards the front of the car and out of the bracket and fold over.
4. Disconnect the electrical plugs press side and pull apart.
